Old 01-17-2014, 09:43 AM   #15 (permalink)
Ironside
Where did you source the dustbin fairing?
One of my colleages in the c90 club, been sitting in his shed for a number of years. They are available from TGA.CO.UK Ltd.
I was wondering : did you finally changed the sprocket ?
Huge choice of rear sprockets from 34 - 50 tooth, unfortunately I'm unable to source anything other than a 14 tooth front sprocket, it's a special sprocket designed for the selectable high/low ratio gearbox. This is not a huge problem, as I can cut and weld a larger sprocket on to the carrier, it's not a easy swap so I've avoided doing it until it becomes necessary. Currently running a 36/14 combination, geared for 60 mph at 8000rpm.
The Following 2 Users Say Thank You to Ironside For This Useful Post:
PeterS (03-27-2014), Quasiff (01-17-2014)
