Wolf_Tm, when you have this project completed please return and post the results.
One thing I've seen in the Pelican Parts forum with front oil coolers is the cautionary tale of making sure the fittings are not constricting flow.
Apparently you can have properly sized oil lines and oil cooler, but if the fitting is too small you will not get the full cooling.
Sometimes fitting a larger fitting is all it takes, for example going from 1/2" to 5/8" is a world of difference in some cases.
