Thread: Aero help
Old 01-17-2014, 03:38 PM   #24 (permalink)
Wolf_Tm
Wolf_Tm, when you have this project completed please return and post the results.
Yes I will for sure!
Just don't expect them in the near future as I'm a proud member of the lift club!
One thing I've seen in the Pelican Parts forum with front oil coolers is the cautionary tale of making sure the fittings are not constricting flow.
Apparently you can have properly sized oil lines and oil cooler, but if the fitting is too small you will not get the full cooling.
Sometimes fitting a larger fitting is all it takes, for example going from 1/2" to 5/8" is a world of difference in some cases.
Exactly, that's why all my oil lines already are dash 10, that is to say 5/8"...
Thanks
Wolf_Tm250 [Silat-Kali] - Parma (Italy)
Suzuki Gsx-R 600 naked
Toyota Rav4.1 Torsen: 240hp 3SGTE swap in progress
Toyota Celica Gt-Four ST205 Snowy White [2.34kg/hp - 600Nm@4950rpm]
EFI University Advanced Tuner
