Originally Posted by 1slw4dr
What is your current tire size setup you're using? I recently purchased a HX in hopes of making my commute less hard on the wallet. I want to at least run a 15x7 but not sure what tire size to go with. I'm stuck with 185/60 or 205/50 I'm very particular on the handling of my vehicles but still trying to get this car to give me 40-45 MPG and you sir are my current motivation lol
Stock tire size is 185/65-14. I have aftermarket 15 inch wheels with 185/75/-15 tires. That extra diameter lowers my RPM's a bit. I would honestly stick with the stock HX wheels or a similar width wheel. The HX's are lighter than most aftermarket wheels, and they allow you to run a skinny tire which helps fuel economy. If you are set on wider wheels for handling, I have run 205/50 on previous cars with good results. Also 195/55. I usually just pick the one with the best prices.
