Old 01-17-2014, 06:32 PM   #60 (permalink)
Arragonis
The PRC.
Question. In your challenge you seem to suggest an either/or choice of DWL vs P&G ? Is that correct ?
In your scenario I would use P&G on the flat part and then use an extra strong Pulse just before the hill Once the speed bleeds off I would then maintain a minimum until the top and I would expect to gain again on the following flat or descent.
If it has been a long journey or I feel lazy then I would maintain a minimum speed / MPG combination on the flat as that requires less effort but still speed up just before the hill to get a push and then again maintain a minimum speed.
The instrumentation available - built in or add in - isn't accurate enough to determine which is better in one run or a collection of runs really but they give a guide, better than nothing.
