Old 01-17-2014, 11:49 PM   #7 (permalink)
Hoffmann
Gas sucks. Use less.
Hoffmann's Avatar
YUGO - '06 Saturn Ion Level 2
Originally Posted by spacemanspif View Post
The ecotec is a pretty popular engine, there may be tuners from diablo, superchips etc. that have economy tunes that can be loaded onto your computer. Its at least worth a quick internet search.
Have you done the simple tune-up things to make sure everything is running well? I don't know what it is but the 2.2s just don't seem to sip fuel like you'd think a 4cyl would....
I remember researching tuning chips a while back, but its seems that I couldn't find anything for the 2.2 ecotec. I would more likely re-flash my ECU for better fuel economy (if thats even possible with a stock ECU?), but coming up with a map by myself would be a daunting task. I don't want to brick my daily driver. Ill take a look at diablo or superchips.
Car is well maintained. Synthetic oil or conventional every 3000 miles, no noticeable difference in fuel economy. Plugs are new, timing chain is good, no check engine lights.
I think this car gets what it gets because...well its about 3000 lbs, and has a restrictive header setup and exhaust. and GM typically typically doesnt invest much in friction/efficiency research with their economy cars.
Thanks for the info though. Ill check it out.
I was looking at materials to make my rear wheel skirts out of. I checked out home depot, and its a toss up between the plastic "milkhouse" panel/bathroom panel and light weight aluminum house flashing. 12$ for a roll that is 20" x 10' . The car would look very goofy with diy rear wheel skirts, and Im not sure if I want to jump directly to that without first doing an under-bumper air damn/cover for the front and back. I would like to lower my car to take care of some wind resistance...add better(bigger!) wheels etc, but that would be big bucks for springs unless i could find them used.
in a perfect world, we would commute in ultralight bicycle-type vehicles that reach 200 mpg, but this isn't a perfect world and I ended up driving a Saturn.
