Old 01-18-2014, 01:39 PM   #184 (permalink)
Disco007
Possibly you do not have this available in your area. Fuel receipt and an odometer on our vehicle. Texas requires these on a motor vehicle and with that and the advent of math you can do some calculations based on the amount of fuel purchased and the number on miles driven with and with out the HHO turned on. When doing this over many tanks of fuel you can get a reasonable degree of accuracy. You run the gas produced thru a bubble chamber to take out the "Steam" if your system is designed to do that before it enters the intake. If you have studied this as long as I had you would understand the progression of the idea. Now I have to wipe off the key board. Got butter from my grilled cheese on it.
Disco Machine.
