Old 07-03-2008, 03:17 PM   #25 (permalink)
computerpc101
Originally Posted by klrv6 View Post
I was thinking the same thing. Until you can go into the ecu and tell it what afr to run at, just lie to it about the load it's under. It will go to another *lighter* part of the fuel map and put in less fuel. Just be careful...
For my car, 1.5L 89 Honda Civic wagon, I saw a sample of Fuel map of my car, It seems that we can fool ECU to think that " Lighter load" by offset MAP sensor resistor value by resistor. It will offset fuel map easily too.
Of course, If we can change ECU fuel map easily, It is a better choice, We can fine tune is for best fuel map for fuel economy VS power.
Both Map or Atmospheric sesor mod are dirt cheap, below $1, ECU fuel map modify cost more money and it needs time to learn this editing program, That fuel map.... better but a lots harder...
