Old 07-03-2008, 02:23 PM   #5 (permalink)
aerohead
Can you set up some additional lighting along with the flash? I can't properly discern the margins of your blocking.If your top is open,and the lower portion closed,I'd reverse the bias,as your stagnation point is low,not high.That's where you can harvest a higher static pressure to ram the cooling air through.
