Old 01-19-2014, 03:38 PM   #190 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Arragonis View Post
Thanks - you may have done and I may have missed it due to man-flu in my head.
EDIT - to confirm this is a "standard ECU" from an Talon/Eclipse (Mitsubishi ?) but with an updated code chip installed via a socket ? How do you monitor the other things you mentioned.
Again not trolling, I get the basics of ECUs (and plan one for my MGB with a Zetec at some point when I have time, money and energy) and am gathering info.
Feel free to ignore, I am OT.
No problem
My stock ecu with the ECM LINK chip installed gives me control on all these parameters. Plus real-time data-logging and real time tuning.
RPM/TPS:
Target idle,Launch Limit, Rev Limit, Coasting FC Offset, TPS adjustments
Fuel:
Global fuel, Fuel Injector Deadtime
MAF Fuel: not using not running MAF
MAF Clamp:same as above
Speed Density Table:
Load/RPM base table
AUX/Maps:
To run an extra set of injectors and have all control of their maps
Idle Air:
AC on rpm AF off rpm, Coolant based adjustment
Narrow band simulator:
Convert W/B to Narrow band sim if no narrow band O2 is used
Anti Lag System/ Knock Control:
rpm based map to turn on and off anti lag, Knock control activate at users set rpm and TPS %
Fuel Pressure Solenoid Control:
Turn on F/S rpm load base
EGR Control:
turn on and off rpm base, TPS and load base
Dash Controls:
Flash Engine light at knock count set by user, coolant temp set by user
MISC:
Lock in Open Loop Mode, Individual Injector Control, Diagnostic Control etc.
Report DTC:
EGR,TPS,FP,O2,Speed sensor,Knock sensor
ECU Inputs:
with after market 5 volt sensor's and user define naming and pin assignments
The next list I will just post the parmeter and not the table adjustments,
Air Flow Smoothing:
Base TipIn TPS Adjustments:
Coolant Temp. Fuel adjustment:
Fast idle ISC position:
INj. Battery adj.:
LTFT Select:
Load Scale:
Open loop Max OCT:
Open Loop Min OCT:
Open loop Thresholds:
SD Temp. Weighting:
STFT and O2 Feed Back:
Timing Max OCT:
Timing Min OCT:
My Haltech system I'm using to read high pressure turbo exhaust back pressure, (ECM Link reads engine back pressure), second LC 1 Wide band, second speed sensor, second baro map, high pressure map, low pressure map, turbo rpm's high and low, fuel pressure, oil pressure.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
mikeyjd (06-09-2014)
