Old 01-20-2014, 08:59 PM   #19 (permalink)
Frank Lee
It is easy to go TOO STIFF with sway bars. After I lowered my Coupe I thought I'd really make a handling machine outta her by putting the thicker sway bar from an automatic trans car on it. Turns out, the car already cornered very flat due to the lowering and the stiffer spring rates and the new struts and the better suspension link geometry for cornering and the slightly wider alloy wheels, such that adding the bigger sway bar only served to roughen the ride. Stock bar went back in, cornering still good, ride much better.
