What I did to block my grill was to use PVC clear sheeting (like the kind that goes on table tops) from OSH that is like 1 dollar per foot. I stuffed it into the grill, and cut away with a utility knife and tucked stuff into cracks until it looked clean. If you can get at the inside of the bumper, you can tape PVC sheet behind the grille which is even easier.
