Old 01-21-2014, 02:52 AM   #3 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by serialk11r View Post
What I did to block my grill was to use PVC clear sheeting (like the kind that goes on table tops) from OSH that is like 1 dollar per foot. I stuffed it into the grill, and cut away with a utility knife and tucked stuff into cracks until it looked clean. If you can get at the inside of the bumper, you can tape PVC sheet behind the grille which is even easier.
I used a mudflap from a semi trailer to do my grill block. It's washable and easily removable/re-attachable. Here is how it looks:
I removed the upper part as my temp sensor is going out in my car, at least I think that's what it is. When I'm driving, regardless of the load, my temp gauge will fluxuate from fully cold (as if car has been sitting) to half way (normal temp). When it goes fully cold my heater gets so hot it will burn you if you put your hand in front of it. It was doing it before I put the grill block on it so I know that's not the problem.
