Old 01-21-2014, 06:36 AM   #66 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Cobb View Post
Does weight really play that much role in mpg?
It sure does make it far easier to achieve good mpg.
It's one of the reasons old cars can get such good fuel economy: they weigh far less than the current overweight crop.
Everytime a car is accelerated you're paying for the extra weight - and while you can get some of that back thru gliding or regen, most drivers turn the energy into heat (brakes).
The main benefit is in city / suburb driving with lots of stop (or slow) & go traffic.
Once out on the highway at a constant speed, the effect is minimal.
But then ... going at a constant speed isn't the most efficient way to drive
When going uphill, weight is also a negative factor.
You can't recoup all of that energy when going back downhill as it'd lead to excessive speeds - even in a hybrid or EV, you're done with energy recovery once the battery is full.
Less weight also means less resources being used.
Another benefit.
