Whatever pushes out on the center also pushes out equally on both sides. Typically front tires wear out on the outer edges from cornering. Rotate front to rear on same side.
In 100k + miles (several vehicles and tire types) on tires inflated to 44 PSI I have seen no sign of center wear, in fact the tires last a good bit longer at those pressures.
regards
Mech
