Old 01-22-2014, 12:22 PM   #37 (permalink)
slowmover
90 day: 19.36 mpg (US)
" . . I take dinner near the interstate each week and can tell you that a lot of the Mesilla Valley Trucking Co. rigs are going by with the Trailer-Tails folded and stowed.I don't know why this is so".
MVT may be an LTL line (less than truckload), and, if there are several customers and consignees in the D/FW metro area then aero aid deployment would be a time-waster; 3-stops to unload, and two more to re-load, for instance.
If a TL line, then there may be a dedicated customer near to Sanger where they are headed. Maybe they have a yard in that area. If they do, then local drivers loading trailers to enable the long-haul crew to drop and hook would also make sense. Etc.
I see them coming out of Laredo, frequently, and all is deployed. The firm does have driver FE incentives in place.
I am a bit surprised not to see more "aero" rigs coming out of Laredo as much of this is dedicated service (fewest changes in conditions for equipment [all Interstate]; long distances travelled; full truckloads), instead what I see more of is maybe an undertrailer diverter and drive axle full covers. Todays conventional tractors are already pretty aero, overall.
Of course what I cannot see is what is under the hood and the drivetrain management system. Electronic logs play a part in this as they constitute a barrier to driver income hours and miles/fuel is more easily predicted.
Many of these trucks will not idle more than 5-minutes within "comfortable" temp ranges for the drivers trying to sleep (the range is too short), and that many rigs now have APU's onboard (CA bans them [a-holes]) which is a better solution. Idle restrictions and E-logs makes fuel cost predictions far easier (dispatch thinks in terms of distance between zip codes at a known total time; if fuel burn differences between drivers is narrowed, then it is an economy).
Even loaded (usually at 74-77k gross) I can easily out-accelerate these "econo trucks' whether they are loaded or empty. But what I do (oilfield service) is drastically different than what they do. Etc.
The Following User Says Thank You to slowmover For This Useful Post:
aerohead (01-22-2014)
