Old 01-22-2014, 05:41 PM   #6 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
double check timing before ordering some rockers. while you are checking timing might be good to do a leak down test to see if valves bent. if timing was off they probably wont warranty the head. did you install new timing chain, guides, and tensioner?
Burn lean and prosper \\ //
