Guess thats the advantage of having a gas and electric engine? Using both, neither generate enough heat to need active cooling?
Maybe you can wrap your motor and speed controller in copper coil to attempt to water cool it and in turn use that water for heater?
Originally Posted by TheSGC
I use the air in the summer to cool the motor and controller so blocking all year round isn't an option. I'm going to pickup more corrugated plastic this weekend and build a grill block and see what that does.
