Originally Posted by niky
Perhaps the "higher pressure" part should be further explained, as that part is definitely written poorly. I believe it is meant to suggest the tires can accomodate higher pressures than regular tires safely.
Tires are tested for Coefficient of Rolling Resistance, and they have moment of inertia, without that it is marketing bile. EVERY company says their crap is the best, no point in regurgitating it. And even then it depends on the application.
