Old 01-24-2014, 12:34 AM   #7 (permalink)
Eric Walls
Thanks for the fast reply's everyone..............Keep them coming
The clean black 1998 hx. has a cracked windshield along the bottom where the wiper's lay. Windshield is cracked from one side to the other but in Ohio it will cause no problem an still pass inspection just fine.
Also check engine light is on because of the expensive 5-wire wideband 02 sensor is completely broken off at the exhaust manifold. I mean it's not even plugged in the wire as well as the entire top half of the 02 sensor is snapped off an missing completely so that's 100% the cause of the check engine light.
Also this car A/C has a rather large Freon leak causing the A/C compressor to not engage when all the Freon leaks out. If you add Freon the A/C will work for a short amount of time.
Lastly this car is missing it's in dash radio, no radio at all. speakers are still there though.
The silver 1998 200k. mile HX civic, has a check engine light on for "unknown" reasons I need to scan it to pull the codes because nothing is visually wrong with the motor that I can see. Perhaps Clogged EGR ports could cause the check engine light I don't know, need a scanner. This car's A/C does not work either for "unknown" reason's. It does have a nice aftermarket cd player installed.
The 2003 Civic HX 225k. miles Has working A/C, No check engine light but does have a "Maintence required" light blinking I have never seen that before on a civic. This car has keyless entry/locks factory CD player as well as factory cruise control which is very odd being that it's an HX model.
The front bumper is trashed, along with 1 busted out taillight and the rear bumper needs repair or just replaced entirely if your picky which I am. Owner claims Timing belt an Water Pump were both changed 20k. miles ago but cannot prove it to me. Owner has no idea when the clutch was last changed or if it has ever been changed. Car has palm size surface rust on passenger rear quarter panel. driver's side panel is rust free
What the heck should I do,
Im so indecisive when it comes to spending cash
