Old 01-24-2014, 02:21 PM   #102 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
Deflection is essentially like rolling uphill all the time, and even the small surface bumps in the paving add a little to that.
I don't think your small bumps theory is included in current rolling resistance tests (smooth rollers)...
A larger diameter wheel "bridges" across more of those bumps, and all else being equal, a larger diameter tire will have lower rolling resistance than a smaller diameter tire.
Not entirely because of what you think though, a WIDER tire bridges more bumps too in that case. To use your style of reasoning, why don't cars have 10,000" wheels?
