Old 01-25-2014, 02:35 AM   #7 (permalink)
some_other_dave
Originally Posted by jeff88 View Post
I guess at this point, my question is would it make sense to have shorter gears for acceleration and then taller gears for cruising?
Not really for fuel efficiency. Might be worthwhile from other perspectives, but pretty much the most efficient RPM you can run at is the lowest RPM you can stand.
I don't know how the torque converters in either of those lock. It might be worth checking into, because if one will be locked during cruise and the other won't be (for whatever reason) that would be an extra factor. An unlocked TC wastes energy...
-soD
