Old 01-25-2014, 02:02 PM   #96 (permalink)
jamesqf
Originally Posted by Thenorm View Post
i think the bed is the biggest constraint. you need to fit a 4x8 sheet between the wheel wells, so that governs your width.
Not even between the wheel wells. When I need to carry 4x8 sheets in the Toyota, I have some props (knocked together out of scrap wood) that let the sheets load level across the wheel wells. Drop the tailgate, and they hang maybe a foot off the end. Perfectly adequate for occasional loads.
But why are they so tall? 98% of trucks don't need such serious off road capability.
It's not even for ground clearance. Look at how much of the height (particularly obvious in the bed walls) is sheet metal above the frame.
Also why are the cabs so tall.
'Cause sitting up high helps inadequate people feel important. Booster seats for the ego :-)
