Old 01-27-2014, 08:41 PM   #484 (permalink)
NeilBlanchard
I have had only a couple of things happen that were unexpected: the right rear wheel bearing had to be replaced, and the bracket at the manifold into the exhaust system is now leaking for the second time. They replaced it relatively recently, and now it is "sputtering" again.
The most pressing thing right now is when the gas tank is full, and it is cold overnight, I smell gasoline when I start up the engine, for a few minutes.
Lastly, the light switch on the hatch door doesn't work anymore.
Now too bad for ~156K miles. Still on the original clutch, and the engine is doing fine.
