Old 01-27-2014, 08:36 PM   #1 (permalink)
ever_green
ever_green's Avatar
gueff - '19 Mercedes Benz A250 4MATIC AMG
90 day: 30.55 mpg (US)
My own BSFC chart using software from road dyno
Few months back I posted a thread about modifying my Drive By Wire maps to improve fuel efficiency. Now that I had the Drive By Wire problem solved I started exploring oppurtunities to use the Tactrix adapter (For Subaru and Mitsubishi only) to find my engine's efficiency sweetspot. This was really time consuming and I had to log for hours and hours, anylze the logs and calculate BSFC based on calculated fuel consumption and engine power all estimated by a software which takes into account factors like acceleration, ignition timing, manifold pressure, MAF, AFR and dozen other values. Basically I used 3 different softwares, one that calculates power, one that calculates fuel consumption (based on AFR, MAF and other variables) and one that helps me graph my calculations.
So far I only have had time to explore the 1400-2800 RPM range which is where I spent most my time in day to day drivings. Also excuse the roughness of the illustration. I have only just begun my work.
Here is the final rough copy of chart:
First off i'm not sure how accurate the numbers are. This is in no way a scientific test but usually the road dyno software does a good job on estimating power compared to traditional chassis dyno and can even convert that number to power at the crank. It estimated that my car makes 162hp at full throttle near 5600rpm vs. the advertised 170hp at 6000rpm . So i'm not sure if subaru over-rated the engine or the software is just in-accurate. Anyway I was disappointed with 0.48 lb/hp/hr raing at full throttle at 2400rpm (which is the best BSFC at WOT). I was expecting 0.4 lb/hp/hr. This graph also surprised me because the sweetspot occurs fairly high up where little manifold vacuum is present. For you scangauge users the sweetspot translates to about just under 90% load near 2000-2200 RPM (about 50hp). Also from this experiment, it was obvious to me that fuel enrichment at WOT loads (even though it was only minor enrichment) has negative effects on BSFC.
*Note: I simplified the drawings by truncating the values (not rounding) when illustrating a BSFC contour. So for example a 0.480 island can include 0.48 to 0.489.
**Engine specs: 2.5L SOHC H4 with variable valve lift, 170hp @6000rpm, 170ft-lbs @4400rpm, 10:1 compression with retarded valve timings (to simulate Atkinson cycle?), cooled exhaust gas recirculation.
The Following 8 Users Say Thank You to ever_green For This Useful Post:
Daox (01-28-2014), Joggernot (01-28-2014), JRMichler (01-28-2014), kennybobby (01-28-2014), MetroMPG (01-28-2014), mort (01-27-2014), some_other_dave (01-28-2014), t vago (01-28-2014)
