Old 01-28-2014, 07:47 AM   #6 (permalink)
ecoTex
ecoTex's Avatar
green VX - '95 Honda civic VX
90 day: 59.74 mpg (US)
this is page 296 from your owner's manual.
Your car IS designed to run E10. Older cars and small engines are not.
Help assure your vehicle’s future
reliability and performance by paying
extra attention to how you drive
during the first 600 miles (1,000 km).
During this period:
Avoid full-throttle starts and rapid
acceleration.
You should also follow these
recommendations with an
overhauled or exchanged engine, or
when the brakes are replaced.
Your vehicle is designed to operate
on unleaded gasoline with a pump
octane number of 87 or higher. Use
of a lower octane gasoline can cause
a persistent, heavy metallic rapping
noise that can lead to engine damage.
Do not change the oil until the
scheduled maintenance time.
Avoid hard braking for the first
200 miles (300 km).
In addition, in order to maintain good
performance, fuel economy, and
emissions control, we strongly
recommend, in areas where it is
available, the use of gasoline that
does NOT contain manganese-based
fuel additives such as MMT.
We recommend using quality
gasolines containing detergent
additives that help prevent fuel
system and engine deposits.
Use of gasoline with these additives
may adversely affect performance,
and cause the malfunction indicator
lamp on your instrument panel to
come on. If this happens, contact
your authorized dealer for service.
Some gasoline today is blended with
oxygenates such as ethanol or
MTBE. Your vehicle is designed to
operate on oxygenated gasoline
containing up to 10% ethanol by
volume and up to 15%MTBE by
volume.
Do not use gasoline
containing methanol
If you notice any undesirable
operating symptoms, try another
service station or switch to another
brand of gasoline.
For further important fuel-related
information for your vehicle, or
information on gasoline that does not
contain MMT, visit Owner Link at
. In Canada, visit
for additional
information on gasoline.
owners.honda.com
Honda.ca Official Website of Honda Canada Inc.
Break-in Period Fuel Recommendation
My adjustable WAI / HAI build thread
http://ecomodder.com/forum/showthrea...tml#post408134
