Old 01-28-2014, 08:15 AM   #6 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Oh ok gotcha. If you set it up the same as a kingpin then I don't see why it wouldn't work. The thickness of the bolt shank to the sleeve is going to be crucial.
Just to clarify the bushing will press into the arm and the through bolts will be where it turns? Is the main goal to adapt the 86 and older spindle onto the 87 arms?
Burn lean and prosper \\ //
