Old 01-29-2014, 12:57 PM   #9 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Noap, I haven't actually, and before I bother with it, I'm gonna look through some ball joint dimensions [as soon as I find them] and see if I can find a matching BJ with the flange on the other side, since they're only $12 or so usually.
That would enable me to press in the joint from the 'wrong' side and achieve the same effect while using readily available parts.
The biggest issue preventing me from flipping the ball joint as they are is that the flange is on the wrong side. It's on the stub side from on the OE unit, flipping it over would mean that a hit to the wheel could loosen the ball joint from it's press-fit because there's no physical 'stop' to keep it from moving except a circlip.
I don't necessarily trust my life or the safety of others to a couple circlips.
