Old 01-29-2014, 01:06 PM   #7 (permalink)
oil pan 4
The main use will be powering the welder or air compressor in remote areas.
Plan is to normally keep it set up for high power use.
To keep the gas from going bad I use ethanol free gas with a little bit of 2 stroke oil.
For most outages I hope to just use power inverters. Only going to fire up the generator to cool down deep freezer and fridge and recharge inverter battery packs.
