Old 01-29-2014, 04:12 PM   #34 (permalink)
Frank Lee
Originally Posted by GeorgeWiseman View Post
No, The original transmission was a 3 on the tree, and the mileage I'm quoting actually used that transmission. I didn't change out the 3 speed until a couple of years later. The 4 on the floor came out of a 1973 F150.
The original engine was a 352 which was thrashed so bad (teenagers had owned the truck before me) that my mechanics instructor wanted to have it as a demo model of what all could go wrong with an engine (amazing list and it still ran). He traded me for a 361 that had been donated to the school nearly new because it needed a new cylinder sleeve (they'd left out a wrist pin clip when it was originally assembled).
I'm sorry to say that I do not know where the rear end came from. I only know the ratio because I jacked up one wheel, turned the driveshaft and watched the wheel turn.
Note that ball bearings are NOT good to have in a pickup truck. I think I changed them out at least once a year. Got pretty good at snapping the axels out with a chain.
I love that body style and I'm fascinated by this truck.
Did you build it in '74?
When it surprised the hot cars- going from 50 to 80mph in seconds- did you have to downshift or was it already in the sweet spot and all you had to do was floor it?
I think you swapped that carb onto it- did that engine come with it? Besides the carb swap(?) and the low rear gears, were there any other mods or was the rest of it stock parts?
Re: rear axle origin: Was it Ford or something else? I wonder if you were able to use the original wheels or if you had to run different wheels front and rear. 14" or 15"?
Thanks, I have so many questions about this- I don't want to get hung up on EFIEs or blogs or anything until I can wrap my mind around this truck.
