Old 01-29-2014, 11:36 PM   #9 (permalink)
Xist
Originally Posted by whatmaycome14 View Post
I'm not sure I follow... do you mean cut the body of the car??
I was referring to the trunk extension, although I realize that it is not very long. If you continue the top of the trunk, you may be able to have air reattach after your Kamm-back, but why did you extend the sides? The boat tails that I have seen tapered, like a boat, although you can hardly taper in that space; it almost looks like it flares out somewhat, which would leave a larger wake. As for dealing with a Kamm-back and a trunk, not a hatchback, I cannot imagine a better solution than Christofoo's:
http://ecomodder.com/forum/showthrea...tml#post390835
That took me way too long to find. I am going to go not fail some school.
