Old 01-30-2014, 08:42 AM   #46 (permalink)
sarguy01
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
Originally Posted by GeorgeWiseman View Post
As I explained in a previous blog, the EFIE is not a fuel saver. It cannot lean out the engine more than the CPU will allow (and that isn't much). The EFIE is designed to allow ACTUAL combustion enhancement technology (like my HyCO 2A or HyZor) to work on EFI engines.
The HyCO 2A is $350. Your website doesn't explain what it does. Who in their right mind would spend that much money on a plastic tube with no explanation of what it does? Do I hook it to my fuel line, vacuum lines, shifter cable?? What does it do? You marketing technique is great; you have had all of us sucked to your website to look at your products, but we aren't buying. It didn't work.
The HyZOR is a piece of PVC for $388. This is a Brown's gas electrolyzer? Hasn't it been proven over and over that these sort of kits simply don't work? There are pages of threads on this forum that show this.
1978 Winnebago with Dodge 440. I read this. So you are saying that I need to remove the throttle plate from my car to use the $350 HyCO 2A?? How do I get the engine to rev? Or run at all for that matter?
I checked out your Civic on YouTube. It looks hacked together with its zip ties, open circuit cards, and PVC contraptions under the hood. I could get 50 mpg out of that car without your expensive mods.
George, I'd suggest you stop writing long winded posts with little factual data and start posting some real people with real results.
