Old 01-31-2014, 07:41 AM   #12 (permalink)
Giovanni LiCalsi
Reverse-Trike EV
Giovanni LiCalsi's Avatar
The circulation pump stops pumping as soon as the temperature in the pump reaches 110 degrees. That isn't enough to heat the cold water line.
I have installed these and they are the best. I have worked on the hot water recirculation systems that were designed a 100 years ago that uses a complete pipe loop from the water heater. Those are very wasteful.
Kind Regards,
Giovanni
http://www.steamcar.net/stanley/fastest.pdf
