Something else to consider if you do end up blocking both grilles would be hood pins:
http://www.summitracing.com/search/part-type/hood-pins
Lots of different styles to choose from. This way you can disconnect your current setup and just use the hood pins to hold the hood down. No need to worry about the lever in the grille. Just a thought!
