Old 01-31-2014, 03:28 PM   #29 (permalink)
bikepilot
I'd put that air filter back in asap. Only takes a tiny bit of dirt to trash the valves/valve seats and accelerate wear of the rings/bore. Running without one is an astoundingly bad idea (and probably hurting your mpg).
Did you replace the rotor with the cap? They wear together and should be replaced as a set. I also always replace the plug wires at the same time with OEM honda, which seem to be the best quality available.
FWIW in 220k miles the worst mpg our VX has ever done was 37 I think. That was just all city in hot weather with the AC cranking.
