Old 02-01-2014, 08:03 AM   #9 (permalink)
Simonas
Mazda 626 - '80 Mazda 626 Base
Thanks a lot for the advice.
The car in the pictures isn't mine. Mine is currently up the road a ways from our house, and I don't have the guts to walk all the way there and back with a camera in -15C and high winds. Taking the pictures isn't the bad part, it's walking there and back that would freeze me. That and the car is between a fence and a building, so there is not enough room for me to get decent pictures.
I hadn't really thought about the timing, but I could file off a bit of the Woodruff key and then lap the sprocket to the shaft, tighten it down pretty tightly and that might hold it. Of course, that assumes that the shaft has a taper, and I haven't gotten around to taking the engine apart yet.
The engine currently has 79mm Lada (Russian car) pistons in it. At least, the previous owner said that he had to put them in. I just assume they are 79mm because that is the standard size. For all I know, they could be overbore pistons and that would yield something like 79.4 or 79.8mm. If has 79mm pistons, I calculated that the compression ratio is now 8.8:1 instead of 8.6:1. The only thing is that I don't know how much of a dish the Lada pistons have. I plan to do further calculations when I get it the head off.
Currently a rebuild isn't an option, as I'm short on money, and the engine was rebuilt not too long before being parked. The engine oil is a light brown color, so I'm suspecting that that is the oil from the change after break in. The guy who gave/sold me the car was known for keeping his cars in good condition so I'm not super worried.
Yes, there is a flap, but the hot air intake hose is missing, so I'll have to find another one.
What I wish I could find is a 3.636 differential ring and pinion. Then the ride height could be lowered with smaller tires and the gear ratio would be better. According to my calculations, the engine would run at 2000rpm at 70kmh (44mph). Engine speed would be reduced by 7% or so if I could find one of those ring and pinion sets for a decent price. Like not much over $120 (€90) to get it to my house. I think UK Miata 6-speeds and Australian MX-5s had them...
For mechman800: I don't drink (alcohol), even if I'm old enough to. In this weather I'd much prefer hot tea to cold beer even if I did drink. My philosophy is that if you've never taken the first drink, you'll never drive drunk.
I've looked at various mods for sedans, so I'm not totally oblivious to the ideas. I'm thinking of making the kammback hook to the roof gutters on the top, have a hinge in the middle of it, and then be hooked to the back of the trunk so the trunk could be opened. I still have to make some calculations to get it to work, and as I stated earlier, the weather could be warmer and calmer.
