Old 02-01-2014, 02:47 PM   #14 (permalink)
TurnpikeCruiser
TurnpikeCruiser's Avatar
Big Merc - '94 Ford F150 XL
The Cherry Bomb - '88 Mercury Grand Marquis LS
Luxoliner - '07 Mercury Grand Marquis LS
Team Panther
90 day: 23.63 mpg (US)
Originally Posted by PAFirefighter11 View Post
Something else to consider if you do end up blocking both grilles would be hood pins:
http://www.summitracing.com/search/part-type/hood-pins
Lots of different styles to choose from. This way you can disconnect your current setup and just use the hood pins to hold the hood down. No need to worry about the lever in the grille. Just a thought!
Woah, reviving an old thread!
Interesting thought on hood pins, although the truck probably won't be ecomodded anymore.
