Old 02-01-2014, 02:49 PM   #29 (permalink)
brucey
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Changing the water pump on a 2.4 DOHC 2001 cavalier.
Normally, the water pump is an involved process, but not difficult. Clearly the people who designed the cavalier did not want people changing the water pump when it eventually failed.
The water pump is located underneath the exhaust manifold. And unlike every other FWD car I've worked on, the exhaust manifold is facing backwards. So you have to remove the wheel, the shields, the exhaust manifold, the upper manifold. Just to unbolt it.
THEN you have to open the engine up. Because unlike most other cars where the pump is driven by the accessory belt, the timing chain drives the water pump. Also, there is just no room to work and even less room to see. It's definitely a "Lay on the engine bay while the hood is up" type of job, and even then you're going to have a hard time.
I have nightmares about doing that job again.
The Following User Says Thank You to brucey For This Useful Post:
MobilOne (10-30-2016)
