Thank you all.
Ok. So, a bigger exaust system is a definite.
The PVC is the cold air per say. I may block that off and get rid of the flexible tubbing and close it off with a filter type screen. I think Diesels run better warm and this one runs cold all the time.
The Cam cover is in the trunk, I will put that on this weekend and hopefully some shocks.
An air dam and Euro Plastic front bumpers with some grill blocking are also a good and hopefully cheap way to increase mpg.
I also want to make the car nicer looking so, fix some dents and bruses the car has on the exterior.
Thank you all,
bigC
