Old 02-06-2014, 01:00 AM   #30 (permalink)
iveyjh
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
This might bear a good look.
Manufacturer Honda
Also called Interceptor 250, MC33
Production 1988-1990, 1997-
Predecessor Honda VT250 Spada
Class Naked bike
Engine 4-Stroke, 4 valves per cylinder, 249 cc 90° V-twin DOHC
Bore / stroke 60 mm × 44 mm (2.36 in × 1.73 in)
Compression ratio 11:1
Power 23.9 kW (32.1 hp) @ 10,500 rpm
Torque 23.5 N·m (17.3 ft·lb) @ 8,500 rpm
Transmission 5-speed, wet multi-plate clutch, chain drive
Suspension 41mm showa telescopic fork (front), direct-link monoshock with preload adjustment (rear)
Brakes Single 296mm disc, 2 piston caliper (front), single 220mm disk, 1 piston caliper (rear)
Rake, trail 25°30', 96 mm (3.8 in)
Wheelbase 1,405 mm (55.3 in)
Dimensions L 2,040 mm (80 in)
W 720 mm (28 in)
H 1,050 mm (41 in)
Seat height 760 mm (30 in)
Weight 141 kg (311 lb) (dry)
Fuel capacity 13 L (2.9 imp gal; 3.4 US gal)
Oil capacity 2.4 L (0.53 imp gal; 0.63 US gal)
Turning radius 2.7 m (8 ft 10 in)
