Old 02-08-2014, 09:12 AM   #8 (permalink)
Joggernot
Joggernot's Avatar
With the temperatures in the 30s I blocked off the upper grill as well. That was too much. Temperature went over 220°F, so I had to stop and pull out the foam blocking the upper grill. Next experiment will be to block the upper and open the lower to see what the water temperature does.
