Originally Posted by UltArc
You Know You're An Ecomodder when you fill up so infrequently, you can't remember how to work your gauge cluster to check your mileage!
Seriously, I could not remember how to work the Insight gauge cluster! lol, I didn't want to erase anything prematurely, so I didn't screw with it before I filled up, and it was SO cold I didn't explore after I filled up. So for this tank, I didn't pull my LMPG- but I doubt it went anywhere with such a poor performance.
You know you're an Ecomodder when you've thought of a way to use all the trip meters provided. Trip A is reset each tank, Trip B is reset each morning, and the segment meter is reset each trip.
