Old 02-10-2014, 03:51 PM   #8 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by jeff88 View Post
You shouldn't have to pull the dash off to do it. It will help if you have a friend assist. If one of you pushes the wire/hanger into one of the grommets and one of you grabs a flashlights and pokes their head under the steering wheel/footwell to look for the wire coming through, then pull it through as much as you need, it should be pretty easy without tearing anything apart.
The only rubber grommet I see is the one on the main wire harness and that's buried in the dash, I'll take a picture give me an hour or so.
