So,
I'm still trying to get the 1000A to work.
I have a flashing led, which means something is wrong.. but what..
I've tried to hook up the serial connection, but that seems not to work.. no response.
Does anybody know which values the throttle, current and temperature need to have on atmega pin level? so I can check that?
Or could something else also trigger an error?
I'm sure the atmega works because on power up I can hear the precharge relay switch on and after some time off again.
Thanks
