Old 02-14-2014, 10:27 AM   #13 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Originally Posted by Weber95 View Post
About the grill blocks, your front grill looks exactly like mine on my truck. How did you fasten the pipe insulation to the grill? And for winter months and a short drive of no less than 3 miles that the engine never gets fully warm on. What % of the upper grill should I block, tempatures range around here from 20*F to 37*F in winter. But then again winter is almost over do I really need it?
I did mine more fer seeing what aerodynamic improvements a grill block would accomplish and still provide enough air fer cooling requirements. So you will have to experiment on what yer goals will be fer yer grill block.
I found that zipties or velcro ties worked the best to secure the pipe insulation to the grill once I inserted a PVC pipe inside the insulation. I tried zipties fer durability or velcro ties fer easy removal. I did experiment with a locking cam setup behind the pipe but it was too complicated fer easy removal.
I did install a digital thermometer probe under the hood just so I could keep an eye on what was happening under the hood. Obviously...the probe placement is key so I placed mine between the top of the air plenum and hood. I've seen a range from 30°F to 80°F above ambient while driving distances over 50 miles. Fer warm up times, I can't really say it's decreased the warm up times as I really haven't paid attention/experimented with the grill blocks on or off during the colder months.
The key is to establish a baseline and then see what yer mods will do. If you establish a baseline with yer mods and then take them off...you might be able to extract what the mods did. It will depend on yer data collection and how diligent you are on yer data details.
Dark Aero-The world's first aerodynamic single wheel boat tail!
