Originally Posted by SirKeats
if i was running okay at 12 degrees... should i keep pushing it up until it starts to ping?
thanks!
Yes. Higher the better (until you get detonation/pinging). Increase timing lowers the torque range of your engine. Therefore it'll make a more power down low.
So go crank it back up to 12 degrees.
