Old 02-15-2014, 06:06 AM   #5 (permalink)
RustyLugNut
Just because something is difficult . . .
Originally Posted by ChazInMT View Post
I've got a pretty good sense of things, I try to break things down into simple elements in order to gain perspective on size relationships and scale. It is one thing to say the Earth is 93 Million miles from the Sun, quite another to place a bead smaller than a BB 78 feet from a bowling ball and have that be a model of the Earth Sun relationship. Then to think at that scale the Earth only moves 3/4 inch per hour.
Anyhow, the amazing thing about atoms that most people fail to grasp is that the nuclei of the atom is insanely small, an aircraft carrier shrinks down to a speck smaller than a Millimeter cubed when only the protons and neutrons of it are lumped together without the space in between the electron shells. When you grasp this, you realize that trying to fuse nucleus's together is an incredibly difficult thing to do in a "Controlled" fashion.
Another way to look at it, you want to smash ping pong balls together, and they're 4 miles apart from each other, and they really don't like to be smooshed together. Proceed.
Nuclear Fusion, The power source that has been 20 years away from practical application for 65 years.
. . . does not make it impossible.
The theories are sound. It is just that the technical hurdles are immense. But, often with greater understanding comes enlightenment and the ability to find paths around the problems.
The laser targeting has improved to the point that the implosion action is now yielding more energy than the impacting laser beams. This is significant even if it is not practical. Only a small fraction of a percent of the fuel is being fused. With better implosion accuracy will come greater production of fusion and greater energy output. That is a scientific fact. Better implosion control is just engineering.
