Old 02-15-2014, 09:29 AM   #1 (permalink)
yoyoyoda
Unofficial Master General Car Security Thread (theft deterrent ideas, all makes)
I've been noticing how cars get knocked off on youtube.
Usually car manufacturers put the car horn in an easily accessible place, easily accessible for a thief from the outside of your car.
Like your front bumper, stick your hand up underneath the front bumper of your car and more than likely you will be able to unplug your cars horn from the outside, with the bonnet down and locked.
This thread is to make awareness of these vulnerabilities and find ways to patch them.
I will be relocating my horn sometime tomorrow on my Toyota Camry SXV20..
After all we don't want our rides being stolen, granted it might be a slow get away but we still don't want them to do anything to our cars in the first place.
What else have you guys done on your cars to improve security? Besides the obvious conversion to Stick.
#1 Toyota Fortuner:
Vulnerability:
Disconnect 1st horn from front of car underneath front bumper.
Crowbar up the bonnet on right hand side, 2nd disconnect horn.
Patch:
Relocate both horns to somewhere else.
Or as red devil has said:
Originally Posted by RedDevil View Post
The horn relocation is a good idea, but you may as well just add a horn and leave the OEM ones where they are. That way they will likely trip the alarm and get noticed.
Put a fuse with a lower rating than the in-dash fuse in the leads to the OEM horn(s) so if they short the wires they will also leave the hidden horn enabled, as the extra fuse will blow and disconnect that from the circuit.
#2 ALL types of Steering wheel lock:
Vulnerability:
Steering wheels are usually made of soft rubbery stuff which can be easily sawn with a hacksaw.
Even the multi-point steering wheel locks, and other variants, all have the same problem, the thing that they are attached to is soft and easy to cut.
Patch:
Got an automatic? Use a pedal lock made from steel on the floor instead.
#3 Battery disconnect with a key:
Vulnerability:
What's stopping me from buying the exact same switch online and using the key on your switch? None of them are keyed like regular locks.
Patch:
None at the moment, will update this when I find one.
Unkeyed battery disconnect:
http://www.youtube.com/watch?feature...bC6T6sfZM#t=74
Vulnerability:
As above, what's stopping a thief using a knob and screwing theirs into your disconnect terminal? Or even better yet, whats stopping a thief from just wrapping some electrical tape around the two terminals and reconnecting the battery?
Patch:
None so far.
