Old 02-16-2014, 05:54 PM   #11 (permalink)
nemo
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Active thermal management
The new 2013 Dodge Ram features an active transmission warm-up system where the transmission oil is heated to a controlled temperature by the engine coolant. Active grill shutters and electrically heated engine coolant thermostats are also under consideration for faster warm-up with the grill shutters being introduced in some 2013 models. The fuel economy benefits are small on the FTP test where the cold start occurs at 75 F (about 0.5% benefit each for the transmission and engine warm-up features)
That would indicate that block warmer should be used earlier in the fall and later in to spring. I wouldn't have thought there would be that much of a benefit (0.5%) at 75 F. The cost of the electricity might offset any cost savings.
