Old 02-18-2014, 04:13 AM   #34 (permalink)
yoyoyoda
Originally Posted by slowmover View Post
I added a RAVELCO key to mine a while back.
That is a pretty serious looking security method.
If you want to increase car security beyond this, secure your home too.
All it takes is a gun pointed to you or one of your family members head for you to give up that key, or any key, to the robbers.
A key is nothing, all it is is a bit of metal that lets the car know who the owner is, if the key is stolen then it doesn't matter what security you have installed the car doesn't care who you are, robber or genuine owner.
The best method I've found is having a floor brake lock and storing the brake lock key seperatley from the other keys.
That way If you are forced to give up your keys to a robber you give him the ignition keys and not the brake lock key, this gets you a small window of opportunity where he goes down to the car to check it out thinking he has won, where you can lock the house door behind him or run away with the brake lock key.
I would at the very least install CCTV IP hardwired cameras with a 12v DC feed to the cameras via Power Over Ethernet, which then allows you to run both power and data over the same cable, I use thin ethernet cables to run through doorways to the outside of my house, then repaint them in the same color as the doors.
This combined with a battery backed up CCTV 12v power supply and a modern computer running Zoneminder on a UPS I don't see many methods which they can defeat a system like this without knowing with full knowledge of what will happen beforehand if they break in.
You can hide the CCTV cameras in plain sight, as I do, that gives you the upper hand when robbers come and visit because they won't think to put masks over their faces or get a can of spray paint and spray your cameras, or simply just grab a hammer and smash it.
Thats another good point, keep the cameras up high out of reach.
With CCTV all it is is an evidence gathering tool, thats all, it doesn't stop crimes it just reports crimes to you the owner, usually after the fact that something has been stolen. But its better than nothing.
The reason for using Wired ethernet is:
Wireless IP cameras can be easily defeated by thieves with a 2.4GHz ISM band Jammer.
Wireless is subject to interference from other access points which may change channel onto yours, in effect knocking out the CCTV system.
The Following User Says Thank You to yoyoyoda For This Useful Post:
Cobb (02-18-2014)
